Makeup air.
Bbqjoe
Banned
Location, Location
Might be a no brainer, but here we go.
You're balls to the wall, traveling at top speed. Full throttle.
Air and fuel are flowing at their max.
Suddenly you shut down throttle.
The engine itself is still turning high R's, but now the carb is shut, air is all but cut off, and so is most of the fuel.
The engine still needs to suck in some makeup air.
Where does that come from?
I reckon, it comes from the idle circuit when it partly stalls, then recovers at the lower idle..
Just a guess...
But good question...
Poboy kartman
Senior Moments Member
White Settlement Texas
Besides most butterflies having holes in them, they never shut completely, (otherwise the engine would not idle).
With the high velocity of air moving...there is plenty to keep the cylinder charged enough to cycle.
Bbqjoe
Banned
Location, Location
Just a guess...
I'll buy the idle circuit thing, and yeah, I guess I'm aiming at the stall thing. I have a slide carb. After coming off full throttle rapidly, the engine acts like it sure would like a little more air to chew on while it awaits the next command.
it's as Doug said..
additionally thanks to the narrowed down air passage (slide or butterfly doesn't matter here) the engine in it's next intake stroke will create a low pressure (partial vacuum) in the manifold and carb (behind the slide/butterfly that is)
that in turn decelerates the piston to adapt to the new airflow rate rather quickly.
fuel is not a problem .. in fact chances are it'll be slightly rich at the next combustion cycles..
since the same partial vacuum will also suck on the e-tube like a kid on a slushy straw...
pulling up fuel eventually thanks to the fuel bowl and reservoir not being air tight either.
PS I wonder what would happen though if you defacto CLOSE the air intake completely (say by slamming it shut with a rubber mat).. no.. please do NOT try.. I don't think your engine will like that too much popping gaskets, breaking seals or worse.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Ok Guys
So why do engines often back fire during this deceleration?
Excess Fuel in the exhaust, due to lack of Air?
Bbqjoe
Banned
Location, Location
it's as Doug said..
Yes. Fuel is not the problem at that point, it seems as though air is.
I've got this this thing running pretty darn good now. It doesn't poop out on full throttle anymore, and starts pretty much on the first pull, choke on, and just a bit of throttle.
I accidentally popped a wheelie today from a stand still.
The mix at high R's seems good too. I am now at the leanest setting, and the bike likes it. I just got in, so will check color in the morning.
It's not all perfect, and may never be, I mean how much can you really ask of a one cylinder; but it's running about the best I've had it yet.
I think it would be interesting to see what happens if you could introduce more air at deceleration.
Bbqjoe
Banned
Location, Location
A new development, and a hope for a problem solved.
That is I'm hoping I found the solution to all my carb problems.
Looking at other mikuni's, they have three hoses. Two are breathers to stabilize the pressure in the bowl, and the other is an overflow.
I learned all this through the use of googl fu.
Mine did not come with the first two hoses, but have studs where the others do.
Upon closer inspection, the studs have holes in them, but not at the ends. They are drilled a 1/4 inch further in from the side.
There is no filter set up for them, and if you did attach a hose, you'd block the holes, so they are just out in the open, free to suck in whatever comes along, in my case, dust.
Today, I shall cut the ends off at the drill hole, attach some hose, and terminate them in some sort of air box or something. I'm hoping this will be the solution to what appears to be carb airlock.
The answer will be revealed soon.
Soon, as in a few more cups of coffee, and the rising of the sun.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
"Some sort of Air Box."
How about drill a hole here, in your current air box.
Where the arrrow is pointing, and put your hoses in there.
Bbqjoe
Banned
Location, Location
You could always put a fuel filter on you vent hose to keep the dirt out, and it would be much easier than building an air box.
The ends have been nicely cut off with a dremel cutting wheel.
The challenge at the moment is the hoses.
I found some stuff that's very close, but not quite it.
I shall finish teaching this ham sammich a lesson, then find something.
I may have to go raid my neighbors shed and see what he has.
Flyinhillbilly
The great cornholio
North West Arkansas
I wouldn't because it would be subjected to intake pulses. Just vent it
To atmosphere and I know it'll work. I'm not trying to split hairs, but carburetors can be touchy.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Vented to atmosphere? Would that work, in his constant extreme dusty conditions?
I do not know if those hoses pull "in" or what? that is why I ask.
Flyinhillbilly
The great cornholio
North West Arkansas
That's why I said to put a fuel filter on the end of it.
---------- Post added at 05:09 PM ---------- Previous post was at 05:08 PM ----------
Put a piece of hose on the stub from the carb, then a fuel filter on the end of the hose. Easy peasey japaneesey.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That is what I do with the vent hose from the valve cover, after installing an aftermarket air filter.:thumbsup:
