Looking for info on clone engine racing
outcrydrummer
KART ART
Greensboro, NC
I'm trying to find someone who wouldn't mind me picking there brain about stock box and super box clone engine racing. I'm wanting to get into it with a buddy of mine but I know nothing about it really.
Were looking to do asphault racing.
My cell number is 910 915 0088. If you would shoot me a text I could call you. I would really appreciate it.
Josh
r_chez_08
Should be in the shop...
Cornwall, UK
You would probably be better off heeding over to karting.4cycle.com, not shooing you away, but there is a whole forum specialising in clone racing.
slideways
If you don't know anything about motors then Box Stock is probably the way to go. Get a cheap entry level motor kit and have fun and get seat time. Its getting out of hand with all the tricks and secrets the top builders have in the motors and now they get $500+ for a fast engine in the "stock" class.
The BP class is a motor you should be paying $500-750 for but its going to make 12-15hp and be alot more fun to drive. There's just alot more to learn about maintenance and what parts are inside of those motors.
outcrydrummer
KART ART
Greensboro, NC
I'm pretty mechanically inclined, I'm a mechanic in the army and I'm very familiar with rockers, valves, compression, timing, etc etc etc so that won't be an issue. I'm more looking for info specific to the racing aspect.
Whats allowed in the super box class. what people run. what I can expect to pay for a competitive chassis, what you can and can't run, can you run a predator, etc etc etc
FlatFootRacing
Speed Freak
Easley, SC
No the Preditor isnt allowed in most Super box classes! A decent chassis will run anywhere from 500-1200+ bucks depending on year, and manufacturer. Look at the AKRA website for rules on the SB or Builder Prepared class! Tires are going to be one of the biggest expenses. I spend close to 2000.00 a season on tires to stay up front. If you are jut starting look a buying a used set of tires with some decent rubber left on them. A new set will run upwards of 200.00 bucks! 230.00 - 240.00 is the norm! And depending on what track you will be running some have a tire rule....meaning you can only run one brand of tire, be it Maxxis, Burris, Vega...an so on!
slideways
This is the reason why entry level classes like clones should be on a spec tire with no more than 4" of tread width. If you can't beat the next guy with a faster motor you have to beat him with better traction somehow.
Basically you have to check out the clone section on 4cycle.com. Read the rules on there. My advice is again to get an AKRA clone and build it out of the box to your new kart frame. Learn all the specifics about handling and what makes speed and then go up to BP using your same AKRA motor next season or the season after that.
FlatFootRacing
Speed Freak
Easley, SC
I completely agree... the tire thing has gotten out of hand! I usually win enough to cover my expenses at the end of the season....I have no illusions of makeing a career out of this. For me its for the fun and excitement of it! A spec tire would be nice....we need a little more than 4" of tire to run on dirt though, with the speeds we reach 4" aint gonna get it! My right side tires are 8" wide. The BSP class is the entry level though...the super box or BP class is the next step up!
Check this link out for AKRA Rules:
http://karting.4cycle.com/showthread.php?t=409737
