Lights on clone
mike75925
thinker and tinkerer
Alto, tx
the problem with just running a battery is that if you get the volts too low, it could warp or otherwise mess up the battery.
jfoust
Atlanta, GA
Simple voltmeter from Harbor Freight would set you back a few bucks and would give you instant voltage... Or you could snag a digital one from Fleabay pretty cheap and that solves that problem.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95779
Just seems like the discussion is talking about a heck of a lot of work (and investment) for some lights that could be set up in 15 mins or so with about $40 worth of battery and wiring! I've kicked this same idea around for our kart, and I think battery power is the route I'll go, especially since I'm pretty well equipped for it with all the power wheels gear we have.
mike75925
Alto, tx
i couldn't say. i could probably measure my 160's bolt pattern and give you the specs. the fly's would also have to be the same size.
