Lawnmower
r_chez_08
Should be in the shop...
Cornwall, UK
My parents have a self drive lawnmower with a Honda 4.5hp gxv135 or something like that.
The lawnmower worked fine, until my brother used it, and apparently it just died and wouldn't start again.
I replaced the plug, oil, and cleaned the carb. The engine now runs, but when cold is kinda hard to start, and smokes a bit, and when warm needs choke to start. Finally, it seems to lack power when cutting the grass, as I tried it out on some average length grass, and it bogged down a little, and died a few times. Any ideas? Thanks
solomon
ca
You need to do a plug chop and adjust the mixture. Make sure you don't have a vacuum leak at the intake gasket, sounds like you may be running lean hence needing the choke when warm. Do a plug chop though and you will know.
solomon
ca
Yes, sounds like you are lean or have a vacuum leak at the intake.
Kaptain Krunch
Pro Junk Collector
vermont
Definitely sounds like your running lean. As to why it would happen all of a sudden, absolutely no clue. Start it up and spray carb cleaner around all intake gaskets. If the engine revs up its got an intake leak.
r_chez_08
Cornwall, UK
Thanks for the help guys. I fixed it, by replacing the fuel and giving the carby a blow through with a compressor.
