lawnmower engine questions
DS13
Annoying the Neighbors!!!
Elysburg, PA
Would a push lawn mower engine work well or would the vertical shaft not work? If not, what kind of engine should i be looking at.
TorqueRanger
The questions of the day is ????
Will work for what and what are you doing because we need more info????
B.M.800
TheBeal.
Central PA
A Vertical shaft engine can be used.
linked up to a lawnmower transmision would prolly be the easiest, and cheapest. However a lawnmower tranny is not made for going very fast.
Bluethunder3320
im using a mower engine and transmission... keep watching to find out how itll work. should be driving early spring.
Bluethunder3320
you can also convert them to horisontal shaft engines. most vertical shaft push mowers ive seen have either stepped shafts or 7/8" keyed shafts. the best would be a 3/4" shaft with a 3/16" keyway, but you CAN use 7/8" keyed and 1" keyed.
so to convert them to run sideways you need to do the following:
make a vertical engine mount
make a oil slinger on the connecting rod
make a custom intake manifold to mount the carb upright
rotate the pull start
im going to do this to a 6.75 OHV briggs as soon as i finish my kart. it will probably just be used to say that i can do it... wont have much of a purpose because i doubt it will be very reliable.
