lawnmower engine blade adapter
Thedude
Washington State
I started to convert a vertical briggs to run horizontal today. But I can't get the side cover off because of the blade adapter on the end of the crank. How can you take these off? Mine is rusted on.
I believe a lot of people end up slotting it with a hacksaw or grinder out of desperation. If you do, work carefully to avoid damaging the shaft.
Bluethunder3320
i tried to do this when i was putting my free briggs into my tractor thingy.
it seemed like the shaft was tapered so i realized i had nothing that would fit anyway.
i ended up just flipping over the coned washer at the end and making a pulley to fit the belt i had.
lycsailor17
heat it up with a tortch and pull it off. be careful don't heat it up to much. a few seconds at at time will do it.
lycsailor17
I doubt it. just be careful and aim the torch at the adapter, for a few seconds at a time.
sexyvicta
yeh penetrating oil then a puller. Or use heat. Orrrr put it on an anvil(or similar, i use an old piece of railway iron) and wack it with a hammer from other side.
whatever you do dont give up. They can be a right pain in the arse to remove. Just keep trying and eventualy it will pop off
