Lawn tractor?
REDNECK GOCARTS
Racine WI
First off I would like to say, I know this isn't a go kart but it is dealing with small engines. I have a John Deere 180 lawn tractor that has a sticking starter, sometimes it works, sometimes it doesn't. Do any of you guys know how to fix that with out buying a new starter?
B_Bimmer
Take it apart and clean out the dirt and old grease, lube it up, throw it back together and it'll likely work for another twenty years.
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
I've worked on a few of those crappy John Deeres Transmission, Engine, tires Ect, Ect, list goes on and on so Spray WD-40 on the starters moving parts better yet take it apart and clean the rust up... That's worked everytime for me on the few starters I've had stick ;)
Lefturns75
Podunkville USA in the ozarks
On many of the JD lawn tractors they suffer from a voltage drop at the starter. Sometimes will drag or not work at all even with a hot batt. Add a starter relay kit, ##AM107421 and that problem will go away. When the starter is engaged, this kit allows the full 12 volts to the starter and no more problem. You can find these on "The Bay" or at many parts dealers. Do a search and find the best price. I picked up mine for around $16 and had it installed in less than 15 min. There are also some good vids on Youtube on this also.
obone
Marion, OH
Just a thought on this. You get 12V out of the solenoid to the starter? Or are you saying your starter spins, but does not move to come in contact with the flywheel? I've seen the first were the solenoid is dirty on the inside. You hear a click as it engages, but does not have 12V out to the starter. It just needed broken down and cleaned. This was also on a tractor left outside for a few years. Best of luck.
Lefturns75
If you have one of the older 180's using the Kawasaki engine and built in Horicon Wisconsin, The relay kit will solve your problem. If it is one of those fake jobs built in Tennessee do what ever works for you.
