Lawn Edger Re... erm, Something...
Some time ago, my brother decided to replace his lawn edger with a cheap chinese machine (pics 1 & 2). Around the same time, I was searching for a small 4 stroke engine to suit an upcoming build; I eventually found one but, it was attached to a lawn edger & came as part of a package which included two other bodies.
My first thought was "what the heck am I gonna do with these edger bodies? Then my brother started complaining about his new edger simply not working as it should; for starters, the wheels were too small & simply sunk into the grass &, when it did decide to move, it wouldn't cut properly...
Upon inspection, the first thing I noticed (apart from the tiny wheels & cheap chinese construction) was the engine was facing the wrong direction; instead of the engine turning the blade into the ground leading edge first, it was turning the blade trailing edge first (that's chinese engineering for you...)
Just then, :idea2: (you can see where I'm going with this, right?)
Now, I wasn't gonna simply bolted his engine on my cruddy, old edger, that would've looked less than impressive & porbably would've got me a look of "wtf?" from my brother so, I set about stripping & cleaning my edger in preparation for a repaint & rebuild.
I chose the best of all the parts so, the old edger is the same as but, doesn't look as bad as the one in the pics...
Everything is cleaned &, apart from a light scuff, ready for paint... & then the clouds rolled in...
machinist@large
West Michigan, 49331
Hopefully this project goes better than the riding mower did... Just for the heck of it, maybe you could post a back to back test of the throw away versus your rebuilt unit.....
:thumbsup: :cheers2: :popcorn:
Not a bad idea Pat, I'll get onto that...
Here's yet another piece of pointless chinese engineering; the edger is sitting on a slight downhill slope...
:funnypost: :roflol:
Reminds me of a car I used to own...
Update: Just about all painted; Just need to squirt the wheels tomorrow & start reassembling it...
Funny thing about this edger, aside from the engine, the largest part of it is the handle...
I know what you're referring to, I just don't get why...
If you're trying to say I've been sick for three years, you'd be cutting it short by a decade or two :roflol:
Small update:
Everything is painted (& I do mean EVERYTHING) & slowly being reassembled; with a bit of luck, should be ready to test tomorrow...
Poboy kartman
Senior Moments Member
White Settlement Texas
And all I can think of is how lucky I am to live on the other side of the planet!!!!!!:lolgoku:
Good luck buddy ...I'm sure it will purr like a kitten...... (just hopefully not like mine. .... (you really don't want that thing biting you on the ankles! !!!:surrender:
I already have a vid of the chinese one, I'll get a vid of the "new" one as soon as I can...
So, these machines have a control rod to change the angle of the blade; when I was dismantling the older machine, I noticed that some moron had ground off the end of the rod to remove it from the mech, rendering it useless because, as soon as any pressure is exerted on it, it slips out of the hole in the mech...
This is even more annoying when you consider that, to remove it correctly, without damaging anything, all it needs is to remove one nut & one splitpin...
Anyhoo, so, now I had to "repair" the rod so that it went in the hole easy enough but stayed there; I whipped out the welder & slowly built up the end, eventually forming a small hook. A bit of grinding to finish it off, a quick squirt of paint & problem solved...
Finished!
Ok, here's what you've been waiting for, VIDS!
Vid 1 shows the amount of movement in the Chinese frame, which translates to flex...
https://www.youtube.com/watch?v=0-oI6OYTeD8&feature=youtu.be
Vid 2 tries to show how difficult this machine is to use on grass & how poorly it cuts...
https://www.youtube.com/watch?v=pDU...tube.com/watch?v=pDUaIm06kNk&feature=youtu.be
Vid 3: The finished product in action...
https://www.youtube.com/watch?v=1LeEEQRVPm8&feature=youtu.be
Yes, I know, I need to look into the terrible screech noise
