ubersoldat
Hi, could anyone tell me why do wee need keyways on the rear axle? Are they necessary?
on simple mechanics side.. they unify the axle and its drive and braking parts to make them non-slip attachments to the axle.
Mr.Kibble:Oooh.... that's where you'll have a problem. If you have a hub with the keyway in it, making a keyway in the axle isn't too extremely difficult. You can actually make one with a rotary tool like a dremel and lots of patience. You'd only have to make it long enough for the hub in the area where you want it. If you don't have any keyway on either, however, making one inside the hub would be a pain in the @$$ unless you have the tools to actually make one. Here's a picture of the keyway I made on my engines crank shaft because it didn't have one. I slowly ground away with a metal cutting blade so that it wouldn't be all deformed or too deep.
