keyed kill switch
kendelrk
redneck engineer
westland michigan
so on my baja heat i want to take the push button switch on my handle bars and turn it into a light on/off switch. then i would like to replace the kill switch with this http://www00.mailcar.net/catalog/in...ase&utm_medium=GoogleBase&utm_term=GoogleBase
i want to mount it in the fake gas cap of my baja's fake tank, the problem is i dont know how to wire the kill switch to become the light switch and i dont know how to wire in the switch as a kill switch, im trying to keep everything in working order. can it be done?
jamyers
Buffalo Gap, TX
You'll need an electrical multimeter or at least a test light and battery.
For the keyed kill switch, check for continuity across wires at each switch position, then you'll likely have to hack off that connector and wire it to allow a completed electrical circuit when the key is "on", and an open circuit when it's "off".
Need more info on the existing push-button switch...is it a "push-to-hold" kill switch, or a "push-click-stays-on" switch (can't remember the official term, lol). If it's a basic push-hold-kill-the-engine switch, it won't work for lights unless you just want lights as long as you hold it down.
Heck, switches are cheap - head to your local hardware or automotive store, a toggle on-off switch is usually just a couple of bucks.
The real problem with trying to use a standard ignition switch is the type of switch required. The kill circuit on our industrial engines requires the installation of a "normally open" switch. Hitting the switch closes (completes the circuit) from the coil primary to ground. Unfortunately, the vast majority of automotive-style ignition switches are of the "normally open" variety. This is because in "powered ignition" systems where the coil must receive 12v to run, the ignition switch opens (breaks the coil power circuit) to shut off.
So- If you try to use a standard ignition switch, it will work backwards- off is on, and on is off. That's not too much of a problem- until you come to the realization that it must now me in the "on" position to remove the key- bad news when vibrations can rattle your key right out on you.
So- you need to source a key switch designed for use with a magneto system. Also- Do yourself a favour- install a key switch if it makes you feel good- but install a toggle switch or latching pushbutton in parallel- you don't want to have to screw around with a key in an emergency situation.
jamyers
Buffalo Gap, TX
So- If you try to use a standard ignition switch, it will work backwards- off is on, and on is off. ....
Excellent point!
DOH! why didn't I catch that??? :roflol:
Do the keyed switches for riding mowers ground out the ignition in the "off" position? If so, one of those would work.
As far as the light switch, if that one stays "On" then it should work just fine.
I discovered the same problem. The solution I came up with is a key switch from a burglar alarm where the key can be removed in the on or off position
r97
Measure twice cut once
Massachusetts, USA
Wiring is simple;
-The new headlight switch should be grounded to the frame (should be already) then simply disconnect the wire from the engine to that switch and solder that wire to the + wire for the headlight. The old kill switch can be set to remain in either the off or on position correct?
-The new kill switch is also very simple, first mount it in the gas cap, then ground one of the switches terminals. Finally connect the second terminal to the engine's magneto kill lead.
I did just this on my go kart, I'll tell you it seems cooler than it is, but that's okay. I used this key switch I got on ebay, which was much easier because it has only 2 terminals and the key is removable in both positions.
