Kawasaki 650sx Jet Ski engine
Smurph
Code Poet
Chattanooga, TN
A friend and I have a 650sx jet ski. Winter is coming, and he doesn't ride it, and we want to put the two-cylinder two-stroke engine on a kart. The problem is, he said it has some type of water intake. Sounds like its cooling system draws from the water its in (I know nothing about jet skis, or other personal watercraft).
What will I need to get this running on dry land? Will it be just as simple as to hook a small radiator up to the intake/output places on the engine?
Kenny_McCormic
Kartless....
Michigan Troll
Some crank adapting may be necessary to get a CVT on there, driver clutch might need to run on a jakcshaft driven by a custom sprocket on the engine. Dunno about cooling, you can hope it uses hose barbs, but manifolds might have to be made. Past that it will go like a ****in rocket!
t0x1k
Vroom
South, NJ
Most engines have a link between the engine and impeller shaft that's like a coupling with rubber between them(the output shaft is then splined for the impeller), unless you figure how to use that shaft which would most likely exploded because of the torque needed to over power dirt vs water. The output on the engine looks like the fly wheel of a standard small engine with maybe 4-5 fins.
I'm pretty sure there's a standard water pump just like a cars engine so that shouldn't be too hard to make.
Smurph
Code Poet
Chattanooga, TN
I think there's a shaft on it between the engine and impeller. I hope might be a better word.
I think we might just try to trade this for a good 125 or 250. I only considered using such an engine because its power curve is unlike most two-strokes. It's rather smooth as it's made to only have one gear (or does it have a CVT in there?). And I want a shifter..
It's my friend's but he said we could use it, and also was the one with the idea to trade it. I went over to his house a couple days ago to yank it and see what it needed to start running, but he just wanted to be lazy all day, and all we did was look at it for about 10 minutes. Useless.
Smurph
Code Poet
Chattanooga, TN
In reading up on the exhaust system (since the exhaust pipe wasn't the typical metal one with expansion chamber I see on most dirt bike two-strokes), and the exhaust pipe uses water, and I have no clue why. Maybe to keep it all cooler?
Do you think I can add a radiator system (a civic radiator is pretty cheap and very light) and use a "dry exhaust pipe" ?
All this considering there is a usable shaft. I'll be honest, I'd prefer trade this off for a decent 125 or 250 two-stroke. Any ideas?
t0x1k
Vroom
South, NJ
I don't know about Kawis, but my bro in law has a Yamaha, and the exhaust goes into the water which creates backpressure on the system.
I think...
theo
You might have a hard time keeping it cool. It has cold water for cooling and recirculated warm might make it run hot.
Smurph
Code Poet
Chattanooga, TN
I would kind of prefer build a kart rather than a cooling system for an engine. I don't feel like I need the extra power.
I think I'm going to toss the idea.
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
My friend Mike the Jetski technician has been talking about using a SeaDoo motor on a kart. The exhaust would be best to be fabricated, the jetski uses lake water from the jet pump to keep the exhaust cool, and uses the same source to cool the motor. So with a closed cooling sytem, (radiator), you would need to supply a water pump as well. The upside is that they have a good charging system, enough to power an electric pump and fan, or you could use a race kart water pump, driven by a belt off the output shaft. You would definitely need to fabricate a drive system/clutch. All in all, it would be a LOT more complicated than using a motorcycle motor, and the cycle trans and clutch system is already there. :cool:
Smurph
Code Poet
Chattanooga, TN
Yeah, That's what I'm thinking. I don't want to build half of a drive/cooling system, I want to build a kart. haha. Maybe another project.
