chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
So I just finished this razor buggy conversion to Gas and it moves ok but has very little power and almost stops on the slightest incline.
Kart and rider weigh 158 pounds total. I stole the following (sticky)and input our numbers:
I have 6.54:1 gearing (11 tooth clutch & a 72 tooth axle sprocket), a 79cc predator 3.5 torque @2500 rpms engine & 13” tall rear tyres:
To find the available torque at the wheels, first you need to multiply the engine torque by the drive ratio:
3.5*6.54=22.90 ft/lbs
Now we need to find the ratio between the axle sprocket & the tyre; a 72 tooth #35 sprocket has an outside diameter of 8;814” so
13” tyre divided by 8;814” sprocket = 1.475
Now we divide the axle sprocket torque by the axle sprocket/tyre ratio:
22.90/1.475 which gives us 15.53 ft/lbs of torque at the rear wheels.
How many pounds of torque are needed to make this kart move.
158pound total kart and rider.
Should I put on a 60 tooth sprocket?
Try to find 11" tires? both?
