Kandi wont start from ignition switch
Sean0301
Hello,
I have a three year old Kandi 49fm5-e 110 cc go kart that had ran fine until last saturday. We couldnt get it to start using the ignition switch. When we turn the switch to on it lights the gear selector light and when i move it to the start position i hear a click in the relays that are in the back but the starter doesnt turn. I replaced the starter solenoid and still no luck. It will start and run if I jump across the solenoid using a screwdriver but no luck unsing the switch.
Any imput is helpful as I am not very familliar with how the safety swiches are setup and I cannot find a good wiring diagram anywhere. I know there is a neutral safety switch as well as a brake switch but Im not sure how to test if they are the issue.
Thanks in advance from both my son and me.
Sean
Staff Murderator
We're not familiar with them either. :D
Is there no back up pull starter?
Maybe you're past that buggy's expiration date? Heaven's to Betsy!
One of our resident experts (in the minority of course) shall be along shortly to assist. In the meantime, welcome, welcome...
Sean0301
Thanks happy to be here. Its wierd since it runs just fine using the screwdriver across the solenoid so I figure its go to be some sort of safety switch thing I just dont know how to bypass that so that I can isolate if that is the issue.
if it starts when you short the solenoid,
there are basically two options:
1) you short indeed the solenoid and the reason for it not starting with the switch is a bad connection from the battery (switch rather) to the solenoid causing it to not close properly, thus not powering the actual starter motor
2) you short against the starter which renders the solenoid pointless and means you again have a bad wiring connection,
tricky part is finding the weak spot.
could be caused by a bad ground connection on either the solenoid or the starter motor,
could be a blown fuse (in which case I'd be amazed about the clicking sounds)
could be a simple thing like a broken wire between the starter and the solenoid (those massive cables workharden thanks to vibration and sometimes break, they can corrode (thanks to ripped insulation) etc.
Test all connections from the starter, via the solenoid to the switch back to the battery poles with a continuity tester to find the weak spot.
Work your way back from the starter motor, (since it starts when shortened out.. chances are there's enough juice just befor that point)
some solenoids require good electrical connection with the starter can to establish a common ground connection
Solenoids require a certain amount of amperage to close the gate line.
so make sure all of those wires are in good condition as well.
while testing, wiggle the wires to see if there is any weak connection or broken leads etc.
if that still doesn't show a continuity issue (i.e. you have continuity all the way)
disconnect the starter and solenoid and instead install a 12V 55W lightbulb (boat or car headlight bulb)
and run that with the wires you'd had the starter conencted to.
(starter, not solenoid!)
see if any of the wires get hot (you should have one part of the wire getting hotter than say a few inches up / down the wire)
if so, swap that, likely some if not most of the leads inside are broken.
if nothing is to be found, repeat with a 12V 5W lightbulb and the solenoid connection instead.
Check repaired spots (electrical tape is your enemy) first,
since most wire harness repairs are less than optimal let's say and tend to break quicker than anything else.
anderkart
Surprise Arizona USA
I agree with Sid.
Here's a link to a wiring diagram that claims to be the corect one for your kart:
http://www.familygokarts.com/pdf/manuals/kandi/110gk/d-kandi-110gk-wiring.pdf
It doesn't list the wiring colors, but Its giving us good clues and showing that ONE of the 2 small wires connecting to your starter relay needs to receive Power (+) from your Ignition switch in the crank position,
AND then the other small wire connected to your starter relay needs to be receiving a Ground (-) signal, that is supposed to be coming from your Shift-position Indicator Displayer panel, when the transmission is in Neutral...
You've already made sure your transmission is in Neutral, right?
With the fact that your starter relay is clicking with the key in the crank position, I'm guessing that either you were sold a defective or wrong type of starter relay, or your starter relay is simply not receiving that ground signal it needs from the Displayer...
So... The first simple tests I'd preform is to use a DC volt meter (or 12-volt test light) to Identify which of the 2 small starter solinoid wires is receiving power (+) when your key is in the crank position, then Test If the other small wire is receiving a ground (-) signal or not.
Perform these test with the small wires both connected and unplugged from the starter relay, then let us know your test results and we'll advise from there.
___________________
PS:
You can test for grounds by simply holding the red (+) probe of a multi meter against the the positive battery post or cable, and then use the meters black (-) probe on the wire.
Or, If you're using a 12-volt test light, you'd simply need to connect its grounding clamp to power instead of grounding it... :thumbsup:
Sean0301
I would like to thank all for you for the advice. Turns out the resolution was to unplug the connection at the gear indicator and re-terminate all of those wires. Once I did that it started right up. I guess that this means that the indicator somehow acts as the neutral safety switch and that connection was just dirty and needed to be re-done. Anderkart you set me in this direction in your post. Thanks again to all of you!
