Jetting Gx340
Pacesetter
Just picked up a used Honda Gx340 for $100. I am starting with the usual filter and header. My Predator 212 needed an upsized jet after these upgrade so I assume this one will need it as well. What size should I go with? Thanks.
It depends on the motor, you will have to do a plug test after the mods, then usually drill one size up at a time till the plug looks good. Others will chime in as to the correct way of the plug test and the color. About tan I think it was.
Oxymoron
Newbesque builder.
Maryland
Yep, light brown is good. White or very light is too lean, and dark to black is too rich.
