Jb weld on clutch
Why not make a guard for the clutch with a tab or plate on the end to hold the clutch on the shaft in case it may drift off. Bolt it to the holes right next to the crank.
Unless Im missing something, why is it all that necessary to have that bolt in the shaft if there is enough tension on the chain, the clutch will float on the shaft and stay being held by the chain?
tetanus
NC
I have never had any luck with jb weld on anything, i dont see it holding up to the rpm either.
