Jackshaft Help
Johnnyboy
Massachusetts
Hi guys,
Last fall I started a complete makeover of my Manco Rattler LXT, but the project soon got shut down by several feet of snow. Now, I'm finally back at it, but I need a little help from you guys. I've already removed the drive clutch (Comet 30 tc) and the bolts on either side of the jacksfaft, but I'm at a complete loss as to how I can disassemble the jackshaft. Can I just punch out the shaft?
Thanks in advance!
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Yes
Once you have the bolts off if the JS you should be able to tap the driven clutch off of the jack shaft watch.
supermanotorious
Winchmaster 5000
New River, AZ
You can, but be careful you don't damage the threads on the jackshaft, some guys leave the nut on so the hammer hits the nut and the nut protects the threads, additionally- you don't want to "mushroom" the end of the jackshaft. If you have snap ring pliers, there is a snap ring in front of the bearings on the other end of the jackshaft. You can remove the ring and push the jackshaft out from that end as well. Hook tools can remove the snap ring as well but with more difficulty.
