Jack shafts help
Shax90
Northwest Ohio
Hello I'm quite confused on how jack shafts are useful and what their purpose is? could somebody help explain it to me?
They are used to make a gear ratio more achievable, when say you cannot get a smaller engine sprocket or larger wheel/axle sprocket, or it's a matter of needing the clearance because of packaging. Meaning you don't have the room for say a 60 tooth #520 axle sprocket, but a 40 tooth #520 will fit. In the case of needing a deeper gear ratio for something heavy and using a large engine, but cannot get the sprockets needed to make the ratio with just 2 sprockets, for example 14 tooth on the engine and a 60 tooth on the axle only gives you a 4.2:1. It's a bit too high for a lot of larger projects. So you'd add a jackshaft. So 14 tooth to a 26 tooth (jackshaft input) to a 12 tooth (jackshaft output) to the 60 tooth axle sprocket gives you a 9.2:1 gear ratio.
Hopefully this helps. If you need a jackshaft ratio calculator here's one that'll help. https://www.bmikarts.com/Go-Kart-Gear-Ratio-Calculator-Jackshaft-Setup
Shax90
Northwest Ohio
Thanks! this helped a lot actually.
