Fun from Boredom
http://www.ebay.com/itm/Go-Kart-Par...ash=item464064f731:g:2HAAAOSwMmBV5bmq&vxp=mtr Can you mount this type of clutch on a vertical shaft engine and it work properly ?
Did you guys miss the bit about
For a vertical shaft, the one you linked is the better choice of the two (chains don't like running horizontal); you will, however, need to use a right angle gearbox with a pulley input & a sprocket output to use it on a kart...
