is this a good idea or not?
ipwnr
toronto ontario
ok so i have seen posts about people cleaning engines and carbs with pure lemon juice and boiling it in etc. so im just gonna ask to see it its a ok or good idea to put some in my gas tank of my 2 stroke pocket bike and will it clean it u or loose performance
etc. cuzz i wann try this.
Bluethunder3320
its plastic i assume?
i would just swish it out with gas, then wash it with soap and water.
the lemon juice and carb thing works when you boil it. putting boiling liquid into a plastic tank might mess it up.
bighead
Pacific Northwest USA
For the lemon to work it must be aluminum. The acid in the lemons reacts to aluminum giving it the cleaning power it does. Plastic or steel you might as well use Dawn or some other degreasers.
robertnz
ontario canada
I used boiling vinegar on a mikuni vm carb on my dirt bike pulled the jets and let it sit in the soup for 30 minutes,sure stinks so do it outside. carb cleans out really nice but has a blackish apperance. I polished it to a shine with stainless scrubby and looks almost chrome. bike runs idles like a dream go for it.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
If you want to clean your carb a bit without removing it, buy a can of sea foam and pour some in your gas tank. Its good stuff.
devino246
Lynchburg, VA
:confused: Can Sea Foam be used on 2 strokes? I thought it was only for 4 strokes. I've never used the stuff, so I don't know.:thumbsup:
Straight from their website:
Sea Foam® is safe for ALL commonly used engines – Automotive, Truck, Industrial, Agricultural, Motorcycle, Marine, Small Engines (lawnmowers, yard tools, etc.), and even Rotary (Wankel Type) engines. 2-cycle and 4-cycle as well as diesel engines, when used as directed, are completely compatible with Sea Foam®.
