is a 2hp enough power
sailorman
Hey
im new to go karts and i can get a b&s off my auto teacher. its in really good condition. just wondering if 2 hp is enough power.
sailorman
o
and i forgot to ask where do you guys get your clutches. or what can i take one out of
RobertD
Administrator
Texas
if you put a torque convertor on it then yes that would rock. If you put a normal clutch on it, then it will run ok, just not very strong. So, if the motor is free, I'd get spend the money on a convertor. if you have to buy an engine, i'd just buy a bigger engine and use a clutch.
2or3wheels
Minneapolis Minnesota
yeah 2 is low, but work with what you got, if you use craigslist or ebay. Ive see 5hp as low as 45 alone and sometime there is whole snowblowers with 7hp engines on them with bad auger so its like a free engine and clutch after you get it running.
Burning Rubber
it depends how heavy ur kart and the driver is gonna be. If u end up using the 2hp u should maybe use light metal to make the frame
