Is 6hp enough?
Bigpat5123
I am building a kart from scratch, progress thread in the build section. I was planning on using a 6hp motor that I already have. It has a 12th CC on it already and I am putting a 72th axle sprocket on single wheel drive. So a 6:1 final drive. Rear tires are 16" diameter and the kart with me in it looks like it's going to be 400+lbs.
Will I move or should I look for a bigger motor?
IT should go, but your approaching the threshold of the capability of the gearing on the clutch.... might need to gear it with a jackshaft later to around 7-9:1 for better performance.
Bigpat5123
If I was to get a bigger engine, I would buy a clutch to match the engine hp. As I am getting into higher weight, is a TC a better option? Correct me if I'm wrong but if I put a TC on with the same final drive ratio. Wouldn't my initial ratio at TC engagement be like 10:1 or 12:1?
This point is irrelevant...
There's only so far you can go before you don't have a choice; once you hit 8hp, the engine shaft is larger, meaning the clutch will be larger, meaning more teeth on the clutch, which will make the drive ratio even worse...
MUCH better...
