is 5.4:1 ratio enough
mdwil
I recently purchased kart with 3.5:1 ratio. Burned up the clutch in about 10 mins. Can increase sprocket to achieve 5.4:1 ratio without modifying the frame or installing a jackshaft. Will 5.4 ratio save clutch? Have 15 inch tires with 6.5 engine.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I think So. I have 6:1 on 15" Tires and I have lots of low end torque. and will Spin the Tires From a stop in the hard pack Dirt.
The Big question is the weight of the art and Driver.
I am 150 Lbs and mine is a simple Yard Kart so Maybe 150 Lbs prolly less.
If you have a Big heavy Kart and Butt... 5.4 may not work.
