IP cameras
supermanotorious
Winchmaster 5000
New River, AZ
So if you followed the great New River easement wars of 2018 you know I invested in some cameras to see all around my property. Well I've bought more that can't be connected to my DVR and just run on the WiFi.
I have some creative ideas on where to mount them but their stupid power transformers are my hang up.
Have any of you gotten creative with powering these IP cameras?
I want to install one kinda remote, WiFi is there, but not power. I could weld a secure battery box to mount near the camera and pair it with a solar panel.
I would need to reduce the 12V or 6V battery to working voltage for the camera. Ideas?
anickode
S.E. Michigan
Find a cigarette lighter power supply that outputs the right voltage and has the right barrel plug and chop it up.
65ShelbyClone
SoCal
What voltage does the camera need?
I'd find out what kind of current it pulls first. Constantly transmitting video over WiFi is going to use a lot of juice. It would help a lot if the camera has some kind of a "wake on motion" power saving feature.
No actually DON'T!
cig lighter converters are the cheapest and worst way to step down the voltage (too much loss ~30% of the power is wasted)
You can find buck converters on ebay specifically made for Arduino and alike ...
or even better check adafruit for such converters.
They are more expensive alright but usually within less than 5% of loss.
And they can be set to whatever voltage your camera needs..
(5V or 3V or even 24V or whatnot)
In case of a 5V camera however, (USB powered??)
you can savely hook it up to a 6V battery,
as long as you have a current limiter.
The camera will have an internal voltage regulator
(I have not seen anything without one yet that runs on 5V..)
And that voltage regulator tolerates at least 7Volts
(usually 9 sometimes 12) but since we do not want to take any risks.. let's assume 7...
And if you are worried about the 6V..
then just get a loooong USB cable (cheap one) I got a 10ft cable
that has an internal voltage drop of ~.9V
bringing your 6V battery to 5.1 ;)
(still wasted energy.. but should still be better than the chinese six leggers you find in most cig lighter adapters)
PS If you camera has no motion detection and want one for power saving..
adafruit offers you all the small goodies you need to toggle the power on motion detection,
it takes time of course from detected motion via handshake protocoll to actually transmit but depending on signal strength that should be within 2or3 seconds
plus the cameras bootup time of course.
supermanotorious
Winchmaster 5000
New River, AZ
Wow, sometimes I'm a ding dong, these cameras run on 12V so no step down required. So yes jmaack your setup is what I have in mind, except I'm going to mount to the wood power pole in my front yard where power comes in from the street. I'll fabricate a rack to hold battery box and solar panel, I'll be sure to get some pictures up when done. Will be kind of wild to see a 12V battery box suspend 15'+ in the air
jmaack
I just realized that it looks like that is my video. it is not. I have used his ideas for myself.
supermanotorious
Winchmaster 5000
New River, AZ
