it's exactly the other way around..
same bore more stroke...
(gx160 is 68x45mm bore stroke (163cc) and gx200 is 68x54mm bore stroke (196cc) )
So no, the
crank is the main difference.
IDK if the GX160 case has enough of a cylinderwall to allow the full GX200 stroke
(essentially rendering it a gx200)
worth to test, afaik everything else about the crank's critical dimensions is identical...
the GX160 head is the "better" of the two actually..
they have same size valves (24.5 and 27.5 mm) and more compression
(especially older e14 heads) for identical fill rates and a bigger oomph
according to the manual I'm looking at the gx160 also has a 5° advanced spark
(25° vs 20° BTDC)
So it also likes to rev up a bit easier
EDIT]
shoot the gx200 exhaust sits 4mm higher suggesting a longer cylinder...
chances are it won't fit then
