Insulating from Ole man winter...
Half-breeder
"Edit" button removed
As most of you know... the US (for the most part) has/is feeling the effects of winter (some more than others). Past few days we're hitting highs of maybe 50*(got down to 17* the other night). I had plans on doing this project when it gradually got cooler... but gradual doesnt seem to be in 'mother natures' plans this year.
Most all of us have seen/had an ole metal shed on a slab, mine is 9.5'x13'. This project is 'one' way of keeping warm in the shed while working, for pennies an hr.
My wife works for the local flooring company and we recently redid our floors. We tore out the old carpet and put in laminate. The old carpet, I took out to the shed for 'this' project of insulating it for the winter(s). Along w/ the old carpet, I found a section in our other room that was just big enough for the back wall.
I took a bunch of 2x2's I had ripped and cut em to line the top perimeter of the ceiling. From the outside, I screwed in the 2x2's securely... this was my top/upper anchor/nailer. The middle of the walls (hip highth) is a brace that I used as the middle anchor.
I draped the carpet up, so as that the edge of the carpet 'just' sat on the floor(planning on putting carpet on the floor aswell eventually), the excess i pushed up into the end sections of the ceiling as a foothold for the roll insulation ill be getting for the ceiling.
The ceiling I used floor laminate insulation for several reasons.
A. It was laying around.
B. The material sticks VERY well to packaging tape, which also sticks well to metal(girders).
C. Plastic material, to make the ceiling(the middle sections/rows) almost air tight.
D. Easily replaced.
For the doors, I stretched an ole blanket Grant sent me, across the inner doorway... "C" clamped it to the ceiling girders, n sliced a cut down the middle. I then took 2 magnets I had from an old rec center, and wired em into opposing ends of the slice's opening. Now to close the blanket so as that it doesnt 'open' up, the magnets are attracted to each other and keeps the opening closed, or when I want em open... the magnets are used to hang the blanket to the girders or doors.
I gotta 30K btu heater from CL for 50$(tank included) today... and stuck it in the corner. Mind you... Ive only gotten 3 of 4 walls covered and the ceiling is ~ air tight... The heater has a cutoff intake temp of 95*(the gas valve will cut off when the air being sucked in reaches 95degrees). Today it was bout 45* outside, when I kick on the heater. In 3 mins I could feel an urge to remove my jacket... by 6 mins I had to remove it. At 8 mins sweat formed, and by 10 mins, it cut off. I stepped out to the comparatively chilly air to cool off. I got to doing something that took alil over an hr to finish, then returned to the shed. I kicked on the heat again and this time it only took 5 mins to kick off(3 mins to sweat).
After the rest of the project is done Ill do more tests/runs... but for a metal shed (in the shade), I think I should have lil/no issues staying warm this season.
Half-breeder
Still waiting on wife to bring home more scraps... but in the meantime... it got down to 36* out the other nite, here. I went out and fired up the 'jet'. W/in 15mins I had my coat off and was slightly sweating. I kicked on the area fan to move the air more, which kept the temperature, but removed the sweat(human condensation)... for about 10 mins(25mins total run time)... inwhich I turned everything off and started a movie (Avengers... 2hrs). Throughout the entire movie the temp never dipped below 70*. I stuck around for alil over an hr before I felt that I needed to put a jacket on again... 65*.
So, a total of almost 4 hrs of warmth w/ 25 mins of heating... not bad for insulating an all metal shed on a cement slab...
... just something bout a go kart on carpet!!! :thumbsup:
https://www.youtube.com/watch?v=DZmBrqtKvVA
machinist@large
West Michigan, 49331
35k btu is seriously on the overkill end of the scale for that small of a space... Does it need 110V, or is it peizo start/thermocouple shut off? If it's a 110 model, you can get a stand alone thermostat that just plug's in between the heater and the wall socket. That way, you can set the temp where you want it.
That could come in very handy if you've just painted something, and want to keep the temperature constant until it dries, but can't be there to babysit...
Axx3d
MN
These are solid little therms if it comes to that..
http://www.homedepot.com/p/Suncourt...-Temperature-Sensitive-Switch-DS100/100028788
Half-breeder
Yea... the 'jet' is way over kill, I know, but for 50$ one doesnt complain too much. The heater is electric fan driven. Im pretty sure the gas cuts off if/when the fan is powered off (for safety)... but wont reignite/continue gas flow, unless the gas button is reactuated and the igniter reengaged (2 button ignition system).
machinist@large
Do a little digging; if you can use a stand alone thermostat, it gives you so much flexibility........
jeeperjoel
san bernardino co., CA
garage is big, 2 1/2 car, very high ceiling...have good 220v shop heater, worked great in old house, but only 110v in this house... from pole... will have to run generator if i wanna use it... :)/)
n3480h
NW Iowa
Might want to be careful about firing up an open flame heater just after you've painted something, especially in a small area like that.
Half-breeder
Lol... yea... might be kinda anti-productive... BUT... would keep me warm... once... :roflol:.
If I 'were' to do such a thing like that... I gotta exhaust window at the other end, w/ a fan... took the window from a trailer's bathroom. Would probably just set the 'jet' outside the door instead of inside.
