installing a torque converter
jlnel
MA
hi all, im new to site and karting. I just picked up a kart that was set up for racing, I guess pavement because there is less than inch of ground clearance. I want to add a torque converter on it, I think that will be best suited to where ill ride it, small industrial park, lot of turns and very short straight a ways. at the moment the kart has a 5hp briggs raptor 3 that is directly attached to a live axel via the chain. to start it you must push start and it goes, kart wont idle and stay put.. not really what I want so what I would like to know is what I need to do?? I know it is a 3/4" shaft, that's it, what info should I get from kart to get going> chain length.. size, sprocket size, teeth?? new to motor and this terminology so please bear with me.
anderkart
Surprise Arizona USA
The 3/4" bore Comet Tav-2 kit, (like this: http://www.bmikarts.com/Comet-TAV2-Torque-Converter-_p_988.html would fit and bolt right on your engine.
You'll notice that kit is sold with your choice of a #35 or #41 pitch drive sprocket. So before you order you'll need to determine what pitch your karts axle sprocket is. To do this you simply need to measure the distance between 2 of the teeth on your axle sprocket.
A distance of 3/8" between 2 adjoining teeth = #35 pitch
A distance of 1/2" = #41 pitch.
No one can tell you how long of a chain you'll need, but after your Tav 2 is installed you could simply shorten the chain to fit.
firemanjim
Just kartin' around....
Houston Texas
You could ALSO just get a cent clutch. For street use, a tav is not necessary. And its ONLY $30-50.....
In the other thread you started, it looks like you have #35 chain.
rmm727
Brookville, PA
There is a place on ebay that sells the clone TAV's with both sprockets. $135 shipped with both sprockets. Those sprockets are $10 or more separate.
Half-breeder
"Edit" button removed
That's what/where I got mine, for Christmas(#35 chain). My kart isnt a racing kart(parsay)... but I do primarily drive on pavement(unwillingly... I like clay/sand). It's a wonderful item to purchase... but take heed... it DOES takeup alot more space than a cent clutch. Not sure 'what' kinda kart you have :useless: but 'if' you have a newer racing kart(seat off center... motor next to seat instead of behind it)... then I can mentally see clearance issues... I may be incorrect... but every kart like those ive seen butt hairs that were thicker than the clearance between the seat n clutch...
