Inboard vs Outboard clutch
Russ2251
AZUSA:Powered by LAWN-BOY
What is the difference?
Inboard/outboard can work with sprocket facing away from engine (outboard), or facing toward engine (inboard).
Their use can solve clearance/alignment issues.
Which would be better to toss on a cart?
Both the same just depends on your preference.
Outboard only clutches will not work with some setups.
Inboard/outboard will work with almost any setup.
Also known as bi-directional or straight through.
slideways
I like to run inboard when possible. Acts slightly as a chain guard and on a minibike is a little safer. Downside is that it makes it harder to shoot a little dry lubricant into the bushing before a ride if its inboard.
