ak99
could you make the 160 gudgeon pin fit the 125 by machiening the 125 pistons gudgeon pin hole larger or is it not worth the time and effort ? will the bronze bush little end hold up at high revs though
Good point, I didn't think of that option.
Again, probably is possible but would be a bit of mucking around - especially with the circlip grooves.
What sort of rpm are you planning on doing? The reason I ask is the vintage racing karts that ran the 125cc were heavily modified but they still used the bronze bush so you may be ok leaving it as is ( providing it's not badly worn of course)
