Swabbster
- Messages
- 439
- Reaction score
- 0
here is the story, i bought a john deere sabre for 50 bucks, and i also had a 11hp briggs sitting around with no spark and no carb, the john deere had a 14.5hp briggs that was worn out and needed to be bored and sleeved, i did not know that at the time that i bought it i dumped some gas in the carb and jumped it it fired for a seccond smoked a bit and died, i figured well it has been sitting a while maybe they fogged the motor, so i bought it took it home cleaned the carb it smoked so bad i could not stand it, driving it i could not even breath, so i pulled the motor apart thinking a piston and rings would do fine and the bore was so worn out had tons of piston slop took me about a hour to get the piston out because the bore was worn and there was a ridge that it kept getting cought on just like taking a worn out brake drum off a vehicle, anyway it has sat for about 8 months with no motor so the other day i took the coil off the 14.5 put it on the 11 installed the 11 in the tractor installed the pulley and belt, removed the mowing deck i plan to use it around the house and tow my broke projects, but i need a carb for it, it is a 11hp briggs ic from 1981 any 11 or 12 hp flat head carb should work of ya and the carb from the 14.5hp ohv will not work the bolts spacing center to center is about a half in to long,
