I keep shearing my flywheel key.
klicky96
Sandusky, Ohio
Alright guys, I have a 5.5HP Tecumseh Snowking OHV engine. 4 Stroke. Bought it 2 summers ago. Well at the beginning of january, I took her off my yard kart and put her up on the shelf. Let me remind you that she ran perfectly fine when I put her away.
So yesterday, I was riding, and for some time now, I knew this engine needed rings, but I figured I'd ride her till she died, then rebuild her. This is a different engine by the way.
So as I was riding down my trail, I began to lose a lot of power, so I knew the rings were done completely. brought her back to the garage, removed the engine from the kart, and put my 5.5 on there.
So heres my problem. When I got the axle and engine all situated up, I tried starting her, and she would backfire like crazy. So I knew the key was sheared. I put a new key on, started her up, got about 20 feet, and it sheared off again. :censored: Today, I put in another key, got around the garage a couple times, then on the last trial around, sheared this one.
My question is, what the heck is my problem?
anderkart
Surprise Arizona USA
You should try lapping your crank and flywheel to ensure they fit each other perfectly.
If you go to a good auto parts store, (like Napa) they usually sell a small container of Valve Lapping Compound. Its just an abrasive paste. To lap your flywheel you'd leave the key out, smear a little lapping compound in the flywheels center-hole and the matting crank surface. Then slide the flywheel on and spin it (by hand) against the stationery crank. This will lap/machine both surfaces to fit each other perfectly. You might have to spend 5 or 10 minutes spinning the flywheel and you'll be able to look at the scratch marks in the mating surfaces and tell when they fit each other perfectly.
Then clean all the paste off with brake cleaner, Install a new key and use an accurate torque wrench to tighten your flywheel nut to 45 foot-pounds. As your tightening, and your torque wrench reads 45lbs, hold that same pressure on the torque wrench for 3 or 4 more seconds. This helps you torque the nut more accurately. It also helps to clean and lube the threads in your nut and crank before torquing, this way you know the threads aren't slightly binding up and lowering your torque specs.
klicky96
Sandusky, Ohio
Well, problem fixed for now. Took one of my high-dollar allen heads, ground it down to fit tightly in the key way, and she ran great without a problem, until I turned the hole kart on its side out in the field. Engine shut off, and because I was working on the engine it was a trial run, I didn't have my recoil mounted. When I put the kart on its side, it decided to start storming. Then, the tornado siren starts going off, and it starts freaking haling! I yanked my strings outta my shoes and got the engine running. The ride back was the most painful ride I have ever had.
souperman000
Westlake Village, CA
lol you should but that in the scariest **** that happened to you in a kart thread.
klicky96
Sandusky, Ohio
I wasn't scared, just pi$$ed off majorly. The fun part was when I decided to hop off the trail and go into the field to get home faster. Its about a 3 foot drop, and I did it with my eyes closed haha.
r_chez_08
Should be in the shop...
Cornwall, UK
You are crazy!
I would reccomend either using a key or no key. Not anything else because it could damage the flywheel or crank and potentially split the flywheel. The key is designed to just locate the flywheel on the crank, not to hold it. The taper is designed to do the holding.
