I have done everything still doesnt start
KartFab
Dallas, TX
Josh, that is where fuel is supposed to shoot out of. That is the emulsion tube and below that is the main fuel jet.
So just reading only wheat you said, it looks like you are really messing with a few things, when the problem is that its a tecumseh. You cant fix that problem, BUT i have worked on a few of those same engines.
1) remove the nut that holds the bowl onto the carburetor you will see a very small hole in the threads of the nut, that is your idle pilot circuit, and it is probably gummed up.
2) remove WELSH plugs from the carb and clean out any air bleeds and whatnot.
3) make sure you really research these carbs and adjustments could be off, preventing it from starting.
To rule you messing up the valve lash and all that other stuff out, just take that carb off, and spray a bit of carb cleaner or starter fluid in that intake manifold. Pull hard 2-3x and it will rev and die within a few seconds. If this happens, you have a fuel problem. And the carb will really need adjustment, and WELSH plug replacement, because thats how you clean a tecumseh carb. friggin have to take out the **** welsh plug just to be able to clean it. if you want, you can buy this stuff at walmart, it is called "mechanic in a bottle" dont add it to your gas, just friggin let that carb sit in the concentrated stuff. IT will break down a lot of the buildup and crud in those carbs.
If you really hate tecumseh carbs, you can just get a pz22 carb copy on ebay for $13 It will literally bolt straight up to the intake manifold on that and man its a sweet little slide carb. Governor will probably grenade inside.
Also, did i mention that the camshaft in that engine is made ENTIRELY OF PLASTIC?! Fun fact. Tecumseh engines suck. Just my honest opinion here.
josh_grace
Carb issues
I bought a new carb for my carter go kart with a 6hp tecumseh engine. This carb when pressing the primer bulb takes gas straight from the float bowl and brings it straight into the carb. The old one was crap and wouldn't work no matter what i did so i got the new one and it worked at first until i was running it and i ran out of gas. Now that there is gas in it every time i pull start it gas shoots out of the carb in puffs like mist. So i took a video of the inside of the carb and it comes spraying out the little pole for the primer where it takes gas out of the bowl
KartFab
Dallas, TX
sounds like you might have fuel issues above the carb too. So what MAY have happened is that after you bought the carb, you ran it out of gas, and all the crud in the tank and or fuel line, or old gas gummed up your new carb. Makes me wonder if you have an inline fuel filter.
josh_grace
There is no fuel filter on it but i did clean out the carb pretty good i was going to take a second look to see if i missed something but what would cause the gas to spray out the way it does
---------- Post added at 09:08 PM ---------- Previous post was at 09:02 PM ----------
Ok i will try that i never would have thought of it. I will try sometime tomorrow or Thursday and i'll let you know how it goes
Clifton
Illinois
Tecumseh isn't much different from any other engine, some briggs models used plastic cam, there are also some honda clones that use plastic cams and not every tecumseh engine has a plastic cam. They all have carburetor problems when you let gas sit in them. My 15 year old tecumseh powersport still starts first pull with the original carburetor.
Tpdingo
Bellmore, NY
Tecumseh is one of those polarizing brands that some people love and some people hate, and you can't ever be in the middle.
nbaffaro
Have you rechecked spark? Have you rechecked compression? Have you rechecked vavles. You could have burnt something up by getting it running.
The middle ground is a Briggs...
For the most part, one can appreciate the flat head motors, now that a few have done a Bronda conversions with success...
Tpdingo
Bellmore, NY
I like flatheads, they are charming motors. You can see their combustion chamber in action from removing a few bolts and the entire thing can be disassembled in a few hours with minimal tools.
And they make a nice smell and noise, especially the classic "blurble" from a straight piped one.
I do remember those briggs we had in school back in the day had a smell..... I guess now its just how it burns the fuel...
KartFab
Dallas, TX
bhahahah i have a pz22 carb on that 'bronda' engine now. Revs to 7k rpm.
I have a big #14, cast iron block with a cool looking down draft carb, horse hair oil bath air filter... Been wanting to change that over to a Bronda setup, haven't had the chance or have a 1" clutch...
