husquavarna riding mower is broken...
Bluethunder3320
this one i couldnt figure out. my neighbor said he drove around a corner then all of a sudden the engine sputtered and got super loud. then the blades started to make scraping sounds.
the engine sounds horrible :mad2: its a 12hp kohler.
the muffler has no holes and its all in-tact. what would cause an engine to suddenly get gun-shot loud with a good muffler?
im stumped. ill post pics and a vid later if i get to it.
:mad2::mad2::surrender::ack2::worried2::furious2:
B.M.800
TheBeal.
Central PA
I would think if the blades are scraping it hit something, get it up in the air and take a good look underneath too...
the-cyborg
Spring, Texas
Sounds like possibly that he may have one or more blade spindle bearings going/gone out on it, and/or bent blades/cutting deck.
Heck could even be that the engine is shot.
detail pics or even a short video would be helpful.
Bluethunder3320
alright guys, im going to go take a video now once i get the muffler back on.
he tells me he just changed the oil and filter.
btw. there is a wire coming from underneath the carb bowl. electronic adjusted jet or something? does it have a computer?
when it runs it almost sounds like its on choke, it idles perfect, give it throttle and it chugs and misses.
slideways
Electronic fuel bowl solenoid. Don't mess with it.
Possibly blown head gasket or exhaust gasket if it is making alot more noise. It may have also stripped the spark plug threads which only shows up when the throttle/rpm is increased.
Homemadgokarts1221
CT
so Matt and i got together today and tried to trouble shoot this thing. One we learned the kholer is a bit@h to work on. and two this thing has some sort of major issue. at some time this thing would fire then backfire then light the carb on fire. WHATT?
slideways
The following are all things that can cause this.
Sheared flywheel key,
Head Gasket failure
Valve spring failure
Valve train (rocker, cam, pushrod etc) failure
Bluethunder3320
haha it caught on fire 2 times and made a ton of smoke. we went through the battery lots of times and had to use my old sears lt1036 to recharge it.
we were stumped so we dragged this thing back over to my neighbors (with the sears) and told him we give up.
then as i looked back at the video i took that morning, i have solid evidence that the flywheel key is sheared!!!!!!!
http://www.youtube.com/watch?v=Rt2pOQuToVE
slideways
Did you take it off yet and make sure? That video alone doesn't prove a sheared key.
Bluethunder3320
im gonna get it back tomorrow and pull the flywheel. well the engine locked up in the vid and the flywheel kept spinning.
machinist@large
West Michigan, 49331
:roflol::toetap05: Tell me this isn't the tractor you were using as an anchor for the wheeley video? (BIGHEAD!!!!! WHERE ARE YOU?When they start snorting marine clean.......:devil2:
Bluethunder3320
okay in an hour or so im going to go pull the tractor back to my house and pull the flywheel off the engine... hopefully it goes back to my neighbors under its own power!
