I picked up this motor kit for my first electric kart build, thinking it would be a reasonably economical solution:
It came with a lot of parts I would have had to source elsewhere. The only problem I'm running into now is finding a sprocket hub to match the included 8mm 54T sprocket. It has a strange bolt hole circle of 64-65mm (~2 1/2") with 6mm (1/4") holes. I'm using a 1" live axle and can't find anything to match on the big online outlets that I know of (BMI, GoPowerSports, GoKart Supply, Electric Scooter Parts). The closest solution I found was at Alfa Wheels, but it's a freewheel hub, so that'd kill my motor braking and reverse possibilities:
That's exactly the sprocket I have, but I can't find a fixed hub to go with it.
Any thoughts on how I could proceed or other sources to try?
I realize I might be able to get whole new sprockets & chain to solve this problem, but I worry it may then be difficult to find a different motor sprocket to match this spindle. Plus, I'd like to save some money and use as much of what I already have as possible.
Thanks!
-Josh
T8F 8mm 54T Sprocket Chain Drive with Axle Axle Shaft Hub Free Wheel Adapter
Brand New Brand New #T8F (8mm pitch) sprocket 54T Accepts #t8f (8mm) pitch chain + Free wheel Adapter + Hub Axle adapter (please select size) The Hub is over sized to fit over the shaft The Hub has external threads metric 35x1.25, threads into the free wheel adapter provided The Hub comes with...
alfa-wheels.com
Thanks!
-Josh
