How to use this school mill? :O
oscaryu1
Our teacher is only a welding instructor (and a very good one at that), but has no idea on how to use the mills/lathes around the shop :(
I've been wanting to resurface some items (cylinders, blocks), with a face mill that I'd obviously have to buy.
Pictures show ya ONE of the few vertical mills I'm playing with... it seems to use a giant collet (like ones in dremels) to attach stuffs :O
And this is the other nubmill:
Sorry for the cellphone pix :\
Leftythenub
Computer Dork
Memphis, TN, USA
Start with scrap metal and play around with the mills. Be prepared to buy a few mill bits because you will destroy a few before you get a feel for the materials you work with. You want a higher rpm for harder metals and slower for softer metals. Just go slow and you will be alright. Set your depth and slowly move back and forth across the metal using the x and y axis. Do not go more than 1/16th of and inch deep at a time. Really you should start a few hundredths deep at first then you can move deeper if you need to. Hope this helps.
Lefty
oscaryu1
Yeah, I have a VERY basic idea of how to use it... (this is my FIRST time ever here :eek:), problem is I have no idea how to attach any accessories :(
Any tips? o_O
And some of the "accessories" that I'm looking at don't seem to have a shaft to attach into the mill... am I missing something?
Rustydog2010
NZ Nutta :|
New Zealand
Is that a chuck on the end? Our one at home just works like a drill press, has a chuck and all the 'bits' have a shaft that goes in the chuck.
Bill CNC
So. Calif. Desert
What exactly do you want to know, ... I can walk you through what ever you need.
Tell me what have you done so far and we will start from there.
Also, ... can you post a more clear picture of the Collet, ... the part you insert the mill bit into?
Also you might want to look here for some basic "Feed and Speed" info.
piddleguy
Might want to look for a good dial indicator as well as the cutter. You will want to start with some scrap metal to get the feel as indicated in a previous thread, however, as with most things in life, setup is the key. A dial indicator is the most useful thing you can have for the setup part.
oscaryu1
Absolutely! I was (planning) on eventually machining my cylinder heads from a car (it'll teach me tons in the process) :)
I can get more pictures on monday, it really is exactly like a dremel collet.
Did the HyperLink not work? :(
Bill CNC
So. Calif. Desert
Well to be honest with you, ... your a little ways off of that goal. You will need to know the basics first. It has been said previously that you should start out on scraps of steel, that is one train of thought that works for sure, ... but it can be an advantage to cutting plastic first.
You can do all the same steps, ... just at a much more accelerated pace.
Before you do any cutting, ... you need to "TRAM" the head. In short, ... you need to align it 90*x90* to the bed. Perfectly straight up and down.
The chuck you have, could be any number of things, but a picture is worth a thousand words.
Sorry, ... Here is the link for the "Speeds and Feeds" http://en.wikipedia.org/wiki/Speeds_and_feeds
If you do a google search for the phrase "Speeds and Feeds" (without the quotes) you will find loads of information.
Regards
Bill
oscaryu1
Absolutely, I'll learn loads the entire way through :D
I'll get pictures tomorrow of the chuck/collet, ect. I'm willing to buy [quite] a few tools for this project. Long shot, but after working with this mill, I'ma try and find a old and used Bridgeport to use... (possibly rebuild it or something?), I'm only 15, but you have to start off somewhere :)
Cam
Nz Petrolhead
Whangarei, New Zealand
To machine a head, flat you will need a fly cutter attachment,
But good idea to start with scrap, id follow what bill is saying he sounds like he has plenty of experience!, so this is all ill add to the thread good luck mate!
Cheers, Cam.
Kenny_McCormic
Kartless....
Michigan Troll
You will need a couple of clamping sets, collet set, wrenches for the collet clamp, various cutters, a dial indicator or two, an edge finder(wriggler), a chuck that fits your collet taper(for edge finder and dial indicator), cuting fluid and some other stuff I'm forgetting. Just don't go and do somehting stupid and cut the table! Some layout fluid and a machinists scale helps too.
I would give some advice but my only experience is 2 hours on a a Bridgeport and I was sort of cheating with a DRO.
oscaryu1
Clamping sets... according to Google don't seem to be that expensive :eek:
Collet set, no idea what type of collet it is. Is it even a usable mill (modern enough to have different collets? Yes, I don't know much :p)
I was looking into them edgefinders a few weeks ago, I can't figure out what you use them for :(
Dial indicator is a definite must for milling (making sure each side is equal and poop right o.o)
To me the mill just seems like a big dremel, just much more accurate :p Is that a true enuff statement? (Probably not)
So I should get a clamping set, collet set, and wrenches, ect, for the mill? Anyone know what type of collet it uses (assuming there are types? ><)
Kaptain Krunch
Pro Junk Collector
vermont
Edge finders (wigglers) are very important for making accurate cuts. Say you have a manifold that needs 2 holes, 3" center to center, 1/4" from the edge, you need to know where that edge is in order to start drilling 1/4" from it.
If i were you i'd use that south bend, it has DRO, which is very hand when your lazy. Hopefully it works.
oscaryu1
I still don't get the point of them... why not just measure it out and poop o.o I've seen videos of it and use, and get the basic idea of HOW to use it, just no idea what the poop it's for :(
Any idea of what things I'd need to start some basic machining? (Say an end mill for some piston lightening xD)
Any links of what I should be looking at? :(
Kaptain Krunch
Pro Junk Collector
vermont
Its a million times more accurate to edge find.
An end mill to lighten a piston? well a good rule is two flute for aluminum and four flute for steel. So a 2 flute 1/2" end mill would be fine. You can also use a fly cutter, doesnt really matter. A cheap end mill set from HF would probably be fine to learn on, its easy to smoke even good end mills if you set the rpm wrong.
As for other accessories, a dial indicator, good caliper, collet set, and some parallels would be good.
