I think I'm going to order the new wheels as soon as I can figure out what bolts to buy to fit on the axle... I feel like this should work out alright! I'll update everyone...
In the mean time, check out what I managed with that poor seized engine:
https://drive.google.com/open?id=1zrRsR82EWx_MzXMp_0hG_sPYlR1FQOTT
https://drive.google.com/open?id=1tws8FkKOTb5pL9KGwICvkNgzrqrYlxT4
It started up! With A MISSING PISTON RING!
And it runs steady! Cuts thick grass!
I only ran it briefly for fear that my missing ring could damage it more...
The engine is smoking so badly probably because of the missing ring, and also because to compensate for the missing ring I dumped way too much oil in there to be safe (safer anyway).
How'd i fix it, you might ask? I sanded the piston with fine grit paper, as well as the bore, until there weren't any parts sticking "out" from a surface that would cause gouging and friction. There's a couple deep scores, but they aren't damaging the piston as far as I know. I'll disassemble after I run it a few more times to see what's up. Compression seems high enough, and it isn't knocking! I think there's hope
Only concern is that I know these engines are supposed to be coated with something inside, which was probably destroyed when it seized and not helped by my sanding (only sanded parts with damage, couldn't have hurt much I suppose). So the longevity is in question...
---------- Post added at 10:13 PM ---------- Previous post was at 10:11 PM ----------
Wow! I forgot how much more compression diesels could get because of injectors. I've always kinda wondered why diesel isn't more popular, because it's more efficient and energy dense. Probably more expensive and requires heavier duty engines I guess.
