How to change engine's shaft diameter
Staff Murderator
Run the engine and hold a file against the turning crankshaft. Might take a while. :D
I do not recommend this procedure.
This is not a good idea. Your crank will never be round and straight enough using a file.
You are going to have to get it to a machine shop and have it machined to a smaller diameter. You can also have a look on Ebay for a secondhand crank that will fit your engine and have a smaller diameter
Staff Murderator
Hey now, he said with basic home tools.
I bet he could come close to making it round... unless the engine's crank is somehow out of round?
with a heavy cast crosstable, a lathe tool holder and cutting tool
bolted next to the crank of the also bolted engine...
you MIGHT have enough of a makeshift lathe to get a decent result.
a file held in your hand.... Nope, I doubt that.
Also.. you still likely need to cut a keyway, which is another can of worms.
So "at home" with "basic tools"...
yeah.. swap the crankshaft against one with the correct PTO.
ML-TOYS
long island, new york
I have tried many ways. files, sandpaper, lathe cutting tools, all no good and dangerous while motor is idling.
Buy a replacement off ebay or get it machined. More than likely you will be buying one because most generator shafts are tapered.
So your basic home tools will be wrenches, sockets, and screwdrivers.
