How to adjust main jet correctly?
jman231994
Australia
Hey guys, I found a carb on an old 4 stroke that has a screw in piece in the bowl bolt which appears to adjust the main jet. My question is, what am I aiming to do with this screw.....Would I want a bigger jet cause Im gonna be running it on a 2 stroke? I really have no idea how to set it up properly lol. Any help would be appreciated. I'll try and find a photo of the type
jman231994
Australia
A bit like these, but older and has a tiny hole in the bowl which I need to fix....love free stuff no matter the condition
sexyvicta
Im using a carb like that on my tecumseh twostroke(100cc), the carb i got off a 5hp 4 stroke, it has a bigger jet than the standard twostroke carb. What number is on the brass nut on the bottom where the needle adjusty thing screws into? mines a 172. Im running it at about 1.5 turns out and its sweet for the little engine. Duno if it'd be big enough for a victa but give it a go. Those chinese 125 pitbike carbs work well on victas and they're realy cheap
jman231994
Australia
Ok, When I get it fitted I might tune it starting at 1.5 turns to make it easier. I couldn't find a number anywhere on the nut, is there some sort of scale comparing turns to jet size? For the time being I'm happy to keep going with this carb, but if I ever tune it up I might need to go to a bigger carb for any noticeable difference anyway.....This is the engine I haven't ported out :arf:
