depends on gearing and clutch. With a centrifugal clutch, your pretty limited, with a cvt you will have more pulling power. When my kart had a 5.5hp engine with centrifugal clutch it would pull me (170lb), plus a trailer (probably 50 or 60lbs) and a person in the trailer (150lbs) fairly well, but it was sluggish on the takeoff. That was with 15" tires and a 6:1 gear ratio.
