how do you remove torque converter?
brycedevore
II have a murray kilowwattgo kart the engine hasnt been started in around two years and I've just bought a 7hp duromax 3/4" cranksaft (same size as shaft on old engine) I have it almost all the way unistalled, but can't seem to get the torque converter all the way off I have everything except the pice closest to the engine off. Does anyone know how to remove this if so I would apreciate the help thanks.
realfast89gt
Kart Krazy!!
cibolo Tx
Well if you post a pic of what you are trying to get off it would help alot.
But the only reason i can see it not coming off all the way would be due to rust or a nick on the crankshaft. Try spraying the shaft with lube (lol) and see if that helps. If not then look at the shaft closely for any burrs or nicks.
By the way, where do u live? I could use the old engine fo parts if u dont want it.
r_chez_08
Should be in the shop...
Cornwall, UK
First remove any rust or nicks with a file or sandpaper (or both).
Then spray it with penetrating (lol) fluid and lube (lol).
If you can get a gear puller on it, then try that. If not a big screwdriver may work.
If you are still struggling, try heating the hub up. Be careful as the oil seal will probably melt.
