How do I measure new connecting rod length?
scottygrape
I am getting ready to place an order for a ARC Billet Rod and Flywheel. How do I know what length connecting rod to get so that it is flat with the cylinder at TDC? Do I just order a .20 rod or do you have to measure it? And if so, how?
Flyinhillbilly
The great cornholio
North West Arkansas
The best way is to find where your piston is at now by pulling the head off and measuring how far down in the bore it is. I use a $20,set of digital calipers to do this, then order your rod length according to the thickness of head gasket you plan to use and the deck height of the piston. I personally shoot for .020 piston to head clearance, a lot of people go .030 for safety. I've been as close as .017, but the piston juuuuuust kissed the head enough to wear the casting texture off of the piston.
KartFab
Dallas, TX
i used a dial indicator that i got on ebay for $30 to measure my pop up to mill a piston. If you dont have pop up, you can still measure the distance the piston is from the deck at TDC with a straight edge and some feeler gauges.
