Branderino
Torque Junkie
I have a honda gx240 8hp. The motor sat for about 15 years. I have completely restored this motor, so it is basically brand new. I also have a carb from a honda gx390. The motor runs pretty well but it is hard to start. Whenever you first start it up it seems like its idling low and wants to die but once you rev it up a bit the idle comes up to its normal position and is fine until you restart it. This happens when the motor is cold and warm.
My second issue is the motor want to die only when giving it a tiny bit of throttle, you either have to give it a bunch of throttle or let off or it will die.
