Honda shadow, 750 ACE Tepm?
Texas
Anyone know en ecact way to tell if the water pump is moving water through the water jackets in the motor?
I had it running for about 30 secs, But i dont have a water temp gauge, so im stuck. I have a lazer thermo, and i researched that they run 108* Celcius but im a feren guy. It goes to cel also though, i just dont know anything about motorcycle engines so i didnt want to run it for too long. Any one have sugestions?
Did the radiator hose start to feel warm? Once the stat gets to the opening temp, coolant will flow thru the rad, and you'll feel the hoses get warm pretty quickly at that point.
Texas
Well thats what i was thinking toystory, but it was more of a risky sugestion.
If i opened up the radiator cap after a min or 2, and water doesnt spew out. But it was warm, that means that water was once in the water jackets, right or wrong?
Well, it would seem so, but that could have just been some errant heat transfer. However, running it for a minute or two will not really indicate the health of your cooling system. It will (or should) take quite a bit longer than that for the thermostat to reach opening temperature.
Closed-loop cooling systems require a sealed radiator cap to function properly. If you take the cap off and the stat opens, it's going to be messy! Has this engine had cooling issues in the past? Why are you concerned about it?
