Honda oddessy w engine swap???? HELP ME
mykol93
Carlise pa
ok so i just got a oddessy droped off to work on it has a arctic cat spirit twin cylinder motor on it. e50 203667 is stamped on blocked i googled it no matches were found. my problem is there are 5 wires coming out of case 2 yellow 2 brown and 1 black. the motor has no spark right now i need to know where to find the wiring diagram or what the wires are. any help will greatly appreciated
Kaptain Krunch
Pro Junk Collector
vermont
I've seen a few sleds on CL with this engine, but never looked closely at them. Maybe you could try contacting arctic cat? the spirit motors were made by suzuki as far as i know, so maybe ask them too?
Kaptain Krunch
Pro Junk Collector
vermont
flywheels on old sled engines can be a pain in the arse to get off. Take off the flywheel nut and get a pulley on the flywheel, using some WD-40 would help too.
DBXFX
if this is the same odyssey with 500cc engine as on youtube, that thing is sweet! it pulls wheelies like nothing.
I got off my stubborn flywheel on my old motor by putting some would block as thick as you can fit behind it, and then knocking the crankshaft with a mallet..i didnt have access to a puller that big
