Honda GX390.
Krustalien
Battlebot builder!
South of Spain.
Hi! Well our lovely 13HP Honda generator was smashed by thieving b*st*rds a while ago now. It was too heavy for them, so they took what they could, turned it upside down and left it.
As it to be expected, it's pretty wrecked. They took the electrical side of things and left the motor - now covered in it's own oil - and the electric motor bit (sorry, I don't know the technical name for this :huh:).
After some jemmying with my dad we got the raw engine free. I expected to see a tapered shaft and what do you know:
http://storage.darkdemon.org/16909/1310944304.jpg
I'm not too worried about this right now, it's pretty lengthy and I'm quite confident that we'll be able to figure out something. That said, I am aware of the possibility of a machine shop giving us a keyway. Or, any other ways to attach the necessary torque converter are extremely welcome! (research tells me the Comet 40?)
So we went about dealing with getting the engine running. After cleaning out the rusty tank and going through a battle with an oily, well, an oily everything, we got it running.
It runs pretty well, all be it loudly and a bit spluttery. One of the things we noticed was that there was a leak somewhere around the carb. We thought maybe it had taken a knock but on closer inspection we saw this:
http://storage.darkdemon.org/16909/1310945117.jpg
It looks to me like an overflow for the carb? We did pour some fuel straight into the carb at one point to see if the motor would fire. Is it that or more serious? More general pic of it here:
http://storage.darkdemon.org/16909/1310945242.jpg (sorry for the terrible focus, you can sort of see the hole underneath the carburettor)
All in all this was a successful day. What's the view on these engines? I know the clones are based on these, does that make the originals good? I'm just itching to know if we struck gold for a kart even if it no longer works as a generator.
Also, can someone enlighten me slightly on how exactly a governor works? My understanding of removing a governor is that it's risky but the extra RPM is worth it? What's the view on removing the governor on this particular engine? Does this engine even HAVE a governor (I have to ask it)!?
Thanks in advance!:wai:
The Honda GX-Series engine is about as good as it gets in small, 4-stroke, OHV industrial engines. They are strong, reliable, long lived workhorses. I loved my GX 340 more than eny similar engine I have ever owned.
Yours, like all others, will have a governor. The purpose of the governor is to maintain speed under varying conditions. This speed is usually 3600RPM. Increase the load, the governor will increase throttle input to compensate. Decrease the load, and the governor will decrease throttle input.
Governor removal is fairly straightforward for a competent person with some tools. You will have to perform a rather exhaustive search of this forum and swashbuckle your way through all the facts, opinions, and BS. There's plenty of each.
Krustalien
Battlebot builder!
South of Spain.
Hi. Well that's good news. I have certainly seen mixed opinions on this. Mainly that removing the governor on a clone is touchy business. How exactly would one go about removing a governor?
Would the potential higher RPM damage my engine? Could it possibly cause problems with a torque converter? You know, higher RPMs making the forces too much for springs?
I honestly haven't got any idea about how you remove a governor. All help is extremely welcome, I'll be relaying any info to my dad. Thanks again.
Governor removal on your engine will fundamentally be the same as for the 6.5hp clones. There's a stickied thread entitled "Helpful Links from the Forum" in the FAQ's subsection that should contain all you need to know regarding the removal surgery.
I'm pretty sure your CVT is safe- once it's maxed, it's maxed- no "overextension" to be had.
With many performance mods including governor removal and the higher maximum RPM that goes with it, you are looking at the potential for a shorter lifespan for your engine (between rebuilds). Do keep in mind that these engines are built to log literally hundreds of hours under varying conditions, and if that lifespan were to be shortened somewhat- would you notice that on a go kart? How many years would it take to rack up hundreds of hours on your kart?
If you are uncertain, I have a compromise for you. You can adjust the governed throttle stop on your Honda, which will take your maximum RPM from 3600 to somewhere between 4000 and 4200. All it takes is a + screwdriver and 10 seconds. Zero mechanical ability required. It is so simple you can do it with the engine running and on the kart. You will pick up a bit of top speed (with the proper gearing, of course) and for all intents and purposes, risk nothing. Just an idea for you.
Krustalien
Battlebot builder!
South of Spain.
Ah, I had heard about that kind of tweak. 600 RPM is a pretty big gain, worth having for no work needed at all. I'll pass all of this info over to my dad and update when things change. I'll also take a look at the that thread, I somehow must have looked past it.
Many thanks, I'm off to bed as it's 3:40am here!:oops:
Any ideas on the carb leak?
The carb pics don't help me, can't really see anything. There's a pretty good chance the float needle is not seating right so it's allowing in too much fuel and flooding. I did have that problem on mine. Very minor.
