Honda GX360K1
TKmech21
Suffolk, Virginia
Hi everyone, I picked up a gx360k1 for 20 bucks, It needs a carb so that is an issue. a bigger issue is it was a generator motor so it has a tapered shaft. I haven't been able to find a replacement crank with a strait shaft so i'm trying to figure out my best options. I got the engine alone withough the generator, so I do not have the armeture in which to make an adaptor, as i read about on here. Anyone pulled the governor out of one of these? I pulled the plate off and it looks pretty self explanitory. But any info on that would be helpful.
As far as a carb, should I just try to locate an oem style or is there some type of aftermarket carbs I can use. I have plans to use this engine in a off road type cart, something for the kids to ride around in the yard. Thanks in advance.
It's gonna cost you, but it looks like you're off to a machine shop to get your crank turned to size.
Is the original carb not intact? Governor's easy, just check the FAQ's- there may be some slight differences in the mechanicals in yours, but all the pertinent stuff applies.
DCProductions
Cockney Ragamuffin
Louisiana, USA
The stock carb is fairly good for the gx360 and is easy to use. An aftermarket carb would most likely be a large Mikuni (in the 30+mm range) and would cost a good deal to tune and adapt. You would also need other modifications to let the Mikuni work at full power.
I don't know what the price difference would be, but I suspect buying a new 1" standard crankshaft would be cheaper than machine work. I suggest comparing the prices.
N5swp
Or.......you could sell me thatvengine since I havevthe carb and need it for my generator and use the $ to buy something you don't need to modify to use
