Honda gx240
Slimmpd
Calera Alabama
When I first got into this site I had just bought my first 2 karts to redo for the kids for Christmas. Thank you for everyone who helped with all the rookie questions.
One of the karts came with a gx240 with a weird crank, 25mm.
Got to either replace or turn it down to 3/4 to use it.
I decided today to see if I could get it running good and the crank out. I sorted out the problems I knew about and found some I didn't but got her running smooth, pretty smooth anyway. Still got to sort out the linkage with the throttle. You can advance it all you want but to throttle down I have to use needle nose pliers to pull back on the governor linkage. I'm sure it's an easy fix so I cruised right by that problem.
I then decided to see how easy it would be to pull the crank. Long story short, it came right out.
While taking the cam shaft out the valve tappets or lifters were hanging down a little on both sides, equal amounts. I put finger pressure on both and with only a little pressure they would not move as to be expected.
As I was fiddling with the rod bolts, the first lifter fell out. I slid it back in the hole and heard something fall inside the head. The lifter can now be pushed all the way in till it's base is flush with the hole/guide in the block. The second lifter is still like it was when I first cracked open the block.
What did I hear fall inside the head. Haven't pulled the head off yet (game was on in 10). Haven't taken the valve cover off yet either.
Spring
Guide
Extra bolt left in by PO?
All the above?
From what I understand the 240 is the wrong size for a race engine, falls between classes but now that I'm into these things, I'm gonna learn on this motor.
Gonna order new springs, billet rod, new flywheel, gov out and it looks like there is a lot of gx390 race parts that will really wake this thing up. Guy near me has a race roller near me I'll probably pick up if I fit in it.
Anyway, what do I need to be looking for tomorrow when I pull the head.
The lifter bone is connected to the push rod bone.
The push rod bone is connected to the rocker arm bone.
The rocker arm bone is connected to the valve stem bone.
Take off the valve cover and fix your bones.
Then Set the Valve Lash to the spec for a gx240, (0.004"? just a guess).
When the lifter fell, the push rod probably also fell. Just shoving the pushrod back will not put in under the rocker arm (not correctly anyway). The pushrod needs to be positioned correctly in the rocker arm. It should be more obvious once you take the valve cover off. Use the good one (the one that didn't fall) and compare.
If you are taking the whole head off, don't fix the pushrods or set the lash until after you put it back on.
If only trying to fix what you mentioned, DON'T take the head off. You don't need to. You'll need to buy a new head gasket most likely, if you do.
---------- Post added at 04:48 AM ---------- Previous post was at 04:34 AM ----------
I have never looked for performance parts for a 240cc.
I'm not as sure as you that they are readily available.
Make sure you find all of what you need before you start buying some parts.
I think they are many more parts for the 196/200/212 and the 390/420, but again I never looked for a 240cc.
Call ARC Racing, Ask for Jody. 800-521-3560
He will know if they make the parts for your engine.
