I have a go kart with a Honda GC160 5HP engine on it. That engine is attached to a "Torq-A-Verter" system and then a chain to the axle. The thing is that when i try to start the motor the "Torq-A-Verter" has to spin causing the go kart the move forward. then when it starts up the idle spin is so fast i have to run after it and jump in the seat, then when i brake it causes the "Torq-A-Verter" to stop so the motor shuts off because it can't spin. i want it to work so that it does not go untill i press the petal or throttle.... the thing turns so fast that the clutch is engadged.. Sucks.. Thanks!
