Honda GC135
Awalker702
Sin City, Nv
I have a brand new honda 4hp in the garage. Was wondering if these are worth putting a little money into. Or can you even get performance parts for it?
The GC series is not commonly used in our applications. Not that it is wrong or particularly bad, just not as desirable as a GX series. The GC is an OHC architecture as compared to the OHV GX. In theory, it's a superior design. That said, the GX has a proven track record (literally, in this case) for being incredibly dependable, nearly bulletproof.
This is not meant to deter you from using it- by all means, slap it on something and have fun. But be forewarned- as they are NOT commonly used, speed parts may be a problem to locate for the GC series, but extremely available for a GX.
While I have not laid eyes on a GC lately, IIRC, there is a slight hump you'll have to deal with. I believe that when the engine is laid in the orientation you need for a go kart, the exhaust port faces forward. This may cause you to have to put some thought into exhaust routing.
rmm727
Brookville, PA
If its new, use it. You won't find any speed parts for it. I think the carb is the same pattern as a GX so you could probably get an air filter adapter for it. I have a GC190 on my one Baja DB30 and I love it. All I've done to it is raised the governor setting to 4000 rpm.
