Honda 70 china clone No fire
fowler
Bullsbrook West Aus
id just re wire the whole thing
dont know about u but i wouldnt buy a non running chineze kart for 200
halve it and id give it a thought
is the little magnet still on the fly wheel
did u paint any cowlings
u may have spoiled an earth
remove anything that needs earthing and cla=ean the mating suface
EDIT
oh and dose it have a low oil sensor or any sensors that would prevent operation
osso12
Kartman
Mesquite Texas
rewire...
ok basic rewire then. There are several wires, sockets, a couple of modules, a starter, switch, kill, a battery to think about, and a stator.... ya dda yadda...
where to start on a basic rewire then?
What are the basic things required and only required?
I don't really wanna but I may have to.
fowler
Bullsbrook West Aus
did u check the other things i put up
id start by cleaning a;ll the grounds
i think the cdi box needs to be grounded (well my cm250 needed it
check for any frayed wires
disvonnect all plugs and clean inside them then check for broken pins
so on and so forth
if u are not sure about the low oil sensor just check your oil and if it is a little low refill it
osso12
Kartman
Mesquite Texas
hehehe..
Im a half dumb ***?
lol!
Two black wires.... I was in a hurry the first time right?
Ahhh...two black wires, and a letter on the back of the ignition switch "G"
well usually "G" stands for ground right?
So instead of hooking the two black wires separately to "G"
like you would normally hook up electronics, I spliced the two black wires together
and hooked them to "G."
Well, when I hooked the wires up to "G" and got a small spark last week that should have maybe told me something was wrong?
What my dumb *** did was hook the black wire coming from the magneto (the kill wire)
to ground!
Right?
Once the engine is started, the black wire coming off the engine is + or HOT.
Not ground. Once we fiddled with it a couple hours we decided to start from scratch.
So my buddy asked me "whats the two black wires hooked together go to?"
I replied " Well, one is the kill wire. DOOOH! Light bulb!
unhooked the two black wires from being spliced together and there ya have it folks.
BUT.... after we got it running, we had issues hooking up the key switch.
Long of the short my buddy managed to burn up the new CDI box by unhooking one of the leads that go back to the coil. He had the kart running, we killed it, he unhooked a wire to the coil to splice into, and turned the key. No start. He hooked the same wire he had unhooked when it was running, and hooked it back up again. No start. What??
We only hooked ONE wire and hooked it back. So I told him that he just burned up the CDI Box. He was in doubt. So to prove that he did burn it up, I got the old CDI hooked it back up started right up! So you have to be very very careful with these Chinese things.. They are not typical like motorcycles and cars by far. So from that point my buddy spent another 2 hours trying to get the ignition to do what it was supposed to do.
Then we unhooked all of it, I told him were each wire should go correctly by using my 12 vol tester, and boom now we have it. It runs now.
First $420 Gets it!
