jman231994
Im wondering if anyone out there with a knowledge of tapers or victas would be able to tell me if i could convert a blade boss into a maxtorque clutch adaptor. Or at least the tapered half of one.
The boss thats on the engine is 1-1/4" in diameter (i think thats how your meant to write imperial stuff) or roughly 30m, the driveshaft is roughly 1/2" or 13mm. It's got two little stick out bits where the blade washer locks on. These bits are pretty much exactly 3/4" OD . The clutch i want is 3/4" ID so thats the size i need. The taper is supposedly 15 degrees. Could someone explain what that means to me? Is it just the taper goes out at 15 degrees from the straight shaft?
The thickest part of the taper is around 3/4" but the boss wont need to be at 3/4" there cause i need a rim for the clutch to sit against.
Ive got access to a metal lathe at school so i could machine it down to the size i want. Anyone think it wont work?
Also does anyone have any ideas on how to make a long shaft nut to screw down on the other side of the clutch and hold it there.
I'm trying to make something like on the link out of the piece shown in the attached image. Sorry for the bad image in the link. Basically one half tapers on and the other screws down onto the threaded bit of the shaft.
Thanks in advance for the help.
http://www.outdoorking.com/index.php?main_page=product_info&cPath=1_17_88_275_306&products_id=2921
). Pulley tensioner clutch kicks cent clutches arse IMO. Cheaper too.
